Features Added in Version 2021.1
Web Authoring/UX
Graphical face-lift.
Interactive resizing of axis margins.
Copy and Export Data reflects collapsed column groups in the Table visualization.
Grand and Sub totals in the Table visualization included in the exported data.
Ability to export/copy the pivoted view of data as displayed in the Heat Matrix graph.
Support for the action mode Parameter in the Action Button part.
Support for the Legend and Action part titles to use the theme’s visualization title settings.
Ability to set the button width in the Action Text Box.
Support for arrays as default parameter values in the Action Dropdown part.
Improved workbook search.
Support for validation of input columns in calculated columns.
Support merging of workbooks with duplicate data table names.
Ability to rotate the text axis labels in both directions (+/- angle).
Support for hiding buttons on the top ribbon.
Support for wrapping layout in horizontal legends.
Support for automatic loading of available extracts in the Panopticon Data Extract connector.
Support for links to translated Panopticon Resources documents.
Visualization
New Numeric Combination graph.
New Text Combination graph.
Support for plotting lines/paths on top of 2D Map Plot visualization.
New Scatter Plot 3D visualization.
Support for the Alpha variable in time series graphs.
Ability to set a minimum range for the time axis.
Support for rubber band selection in the Map Plot visualization.
Support for persistent 3D graph transformations.
Support for data-driven reference lines in text axis visualizations.
Support for showing/hiding vertical grid lines.
Min Interval Length and Max Interval Length settings replaced with Row Height in the Table visualization.
New MMM format string for date/time variables.
Support for Header and Breakdown areas in the Table visualization to have different colors.
Ability to change column text header alignment in the Table visualization.
Support for continuous (point-by-point) coloring of line graphs.
Support to use the item aggregated Alpha to color the line graphs.
Time axis and filter format string improvements.
Ability to show/hide borders in the Time Series Stack graph.
Data Connectivity
New Stream Simulator – Extract connector.
Support for native Kafka keys as real-time ID in Kafka and Panopticon Streams connectors.
No time zone transformation of date columns in the Kx kdb+ and JDBC connectors.
New query builder in the OneTick connector.
Support for time zone setting in the Rserve connector.
Support for token-based authentication (such as OAuth) in the JSON connector.
Support for inner/sub query when using the “Use Query Document” section in the MongoDB connector.
Support for password-protected MS Excel files.
New OTQ listing in the OneTick CEP connector.
Ability to specify nr. of rows when discovering schema in the MongoDB connector.
Support for parameterization using numeric and time arrays in the Kx kdb+ connector.
Default values are displayed in the ActiveMQ connector settings.
Labels changed to Playback Set Size and Playback Interval (ms) in the Stream Simulator connector.
Data Framework
New REST Transform.
Support for multiple key columns of arbitrary type in real-time connectors.
Support for POSIX/POSIXMILLIS as parameter format.
New ISO Date time part in the Time Buckets.
Support for the usage of DATEADD in time window calculations.
New decimal-to-hexadecimal conversion functions in calculated columns.
Support for always logging the username when loading data.
Server Improvements
New API Tokens and bearer authentication to simplify scripted authentication.
New webhooks for alerts.
Server repository infrastructure improvements (leader delegation).
Kubernetes support for cluster and container management.
Bookmarks stored in repository for replication across a server cluster.
Support for automatic data table testing on the server.
Ability to generate alerts for text conditions.
Refactored server caches (query data table and data source).
Support to shrink thread pool for data loads/broadcasts when the subscriptions are reduced.
Support to set the type for folder parameters.
New server content index to support searching for workbooks.
Support to display a notification when the workbook has been changed on the server.
Streams Server
Ability to import and export application bundles.
Analytics
Columns are not duplicated when performing Copy Data/Export Excel option in the Table and Combination graphs.
Support for dynamically updating the numeric color range based on aggregate level.
Support for empty parameter values in Action controls.
Ability to remove line breaks in data with the Action Text Box part.
REST API
New ability to tag workbooks with custom meta data.
In addition, deprecation of the following:
Deprecated the on-demand mode for the Data Extract connector.
Data Object Name setting in the Python connector.
