Features Added in Version 2021.0
Web Authoring/UX
Listing of workbook detected issues.
Source of the error displayed when the aggregate is calculated and the Reference Lines variable column is not calculated.
Ability to set another thumbnail image for workbooks.
Ability to modify root folder permissions, such as to disable public read or write access.
Translated calculated column function description.
Support for mapping between Color and Shape variables in the Shape legend.
Ability for Designer users to create data extracts.
Sorting improvement for the preview table.
Back button respects the browser history to navigate back.
Support to save in the Workbook View Mode for Designer users.
Last edited data table on the Data Table Edit View is displayed when going back to the Open Workbook Edit View.
Support for using double quotes when inserting columns in time series methods.
Default aggregation/format not saved by variables unless changed by the user.
New workbook data table report in the Data Table Edit View (Debug pane).
Support for Upload File (snapshot) or Link to File load type options.
Join key specification not required for Union.
Server Improvements
Ability to monitor and review workbook and dashboard usage.
Ability to monitor and review the logged in users and the frequency.
Improved threading of data loading, broadcasting, and scheduling on the server.
Ability to display the data preview of a data extract from a connector.
New server threading performance metrics and publishers.
New “subscription.log.slow.data.loads.seconds” property that logs if a subscription has been loading data for more than X seconds at the WARNING level.
New “authentication.header.validate.token” property that will validate the token if set to true. Otherwise, it will authenticate every request based on headers.
New “repository.migrate.data.extracts.path” property to migrate data extracts into the repository on start up.
Support for workbook history to be displayed in UTC.
Informative error message when the Tomcat application configuration file (.xml) is not available.
Support for tracking the Logged In Users list when the server is using the HEADER authentication.
Data Connectivity
New AWS Kinesis connector.
Support for Oracle Binary Double data type.
Ability to skip rows from the top in the MS Excel connector.
Ability to open an MS Excel file from a URL.
Generated query displayed in the JDBC Database connector do not have applied parameters.
Ability to load an SVG file from a URL and Text entry.
Ability to select the timezone of the data source for Date/Time columns.
Support for Text connectors to read UTF-8 encoded with BOM files.
Support to hide internal topics for the Apache Kafka connector.
Ability to set the timeout period in the InfluxDB connector.
Support for column generation/specification in the Elasticsearch connectors.
Availability of the Save and Load schema buttons in the MongoDB connector.
Support for SMALLINT and TINYINT data types in the Apache Cassandra connector.
Streams Server
New application component startup mechanism.
New R Transform operator.
Indication that the underlying Kafka is disconnected.
OAuth support in the REST Output connector and REST Transform operator.
Visualization
Ability to select the Scatter Plot’s background image from a URL with support for parameters.
Availability of “Set Snapshot Here” option for timeseries visualizations when Row and/or Column variable is used.
Support for Word Wrap for records variable in the Table visualization.
Support for IRIG Date/Time format.
New Alpha and Shape variables in the Map Plot visualization.
Support for usage of custom shapes in the Map Plot visualization.
Ability for users with a Viewer role to manually control numeric axis setting.
Support for usage of custom shapes in the Scatter Plot visualization.
Ability to display the graph coordinates for line plots (e.g., X-Y plots, Data/Time-Y plots) on mouse over.
Support for Alpha setting for Numeric Line Graph and Numeric Needle Graph visualizations.
Ability to shade area below the line in the Numeric Line Graph visualization.
Ability to always include the zero value in visualizations with numeric axis.
Ability to set the tick format for time axis variables.
Support to assign icons to columns in a Table visualization.
Ability add shape palettes to the Shape variable.
New Alphabet palette with Arial font added to the default Light and Dark themes.
Ability to simultaneously add multiple SVG files to a shape palette.
Ability to download and upload shape palettes.
Support for dynamic sizing of breakdown columns width in the Table visualization.
Reporting
Abort scheduled Email PDF when the data table load fails.
Analytics
Support for selected items and focused item details pop-up.
Support to create custom bookmarks (relative date specification).
Ability to define a custom sort order of dimension or text columns.
Data Framework
New Weighted Standard Deviation aggregation method.
New Weighted Variance and Population Variance aggregation methods.
Ability to define custom labels in the Equal Density and Equal Distance numeric bucketing.
Support for data type casting on columns in the Data Table Edit View in Web Authoring.
Support for blank space trimming for Text Grouping column values.
New special server parameter _current_time_utc.
Support to populate measure values in the Pivot Transform.
REST API
Get login history of one or all users.
In addition, deprecation of the following:
Server temp cache.
Support for workbooks with cached data sources.
Local Kafka connectivity in the Panopticon Streams Server.
Removed the following properties in the Panopticon.properties file:
rest.enabled
authentication.token.refreshable.scope
cache.purge.rate
.cache.service.getresourcedworkbook.queue.size
cache.service.getunmaskedresourcedworkbook.queue.size
cache.service.getdata.queue.size
cache.service.getondemanddata.queue.size
cache.service.getformatteddata.queue.size
cache.service.getdatatabledata.queue.size
cache.schedule.clear.rate
cache.data.plugin.connection.aggregate.size
cache.data.plugin.connection.raw.size
cache.datasource.size
cache.temporary.enabled
cache.diskwrite.enabled
