Features Added in Version 2020.3.0
Reporting
Refactoring of the server-side PDF reporting to using Java Script rendering.
Support to add Table of Contents in the PDF output.
Ability to send Bookmarks in email via the scheduler.
Support for paginated visualizations to scroll past viewport.
Support for multiple tables per dashboard to be inserted in a sheet of the MS Excel file.
Ability to select PDF orientation (Landscape or Portrait).
Support to include the visualization title in the Email Image scheduling task.
New server.host property to define externally visible host that can be used to generate links in emails sent by the server.
New Email Excel scheduler task.
New Email HTML Formatted Data scheduler task.
Support for data table and dashboard parameters on email subjects in scheduled tasks.
Analytics
Availability of new hour or minute based quick ranges in Action Date Picker and Action Date Range Picker controls.
Parameterization of the data table refresh period.
Ability set the data type and corresponding format in the Action Text Box.
Support for default parameters to be arrays.
Ability to set default parameter type.
Support for RGB color source.
Support for parameters reset after running an action.
Support for time series visualizations to align the time window with the time filter box.
Alert notifications record the time of the browser when the alert got triggered instead of the server’s time.
Data Framework
Support for calculated text time series columns.
Server configuration settings for Python and R transforms and data connections.
New ClientTime special parameter.
New DATEADD function.
Export to Excel respects the hidden columns in the Table visualization.
Generate columns detects and generates “T” Date/Time format.
Streams Server
Web UI for MQTT output connector.
New REST Transform.
Ability to select the window type for the Aggregation operator.
Handling of the parameter provider in column definition.
Upgraded kafka-client to version 2.5.
Server Improvements
Python_connectivity.sh, Python_connectivity.bat, and pyro4.py files included in the installation package file to support Python transform in the Visualization Server.
For Altair Units licensing, the DESIGNER user role draws 21 units when designing a workbook.
Ability to see the license information.
New REST APIs to retrieve flattened list of accesses for all folders at once.
Support for parallel repository updates.
Workbook and data table added to the data plugin error messages.
Repository detects if remote repository is unrelated.
Better log messages if the follower loses connection to the leader.
Kafka dependencies upgraded to version Confluent 5.5.1/Kafka 2.5.1.
Upgraded Spring Framework version to 5.1.18.
Upgraded Apache ActiveMQ Client to 5.15.13.
Data Connectivity
Query builder UI for the Kx kdb+ connector.
Query builder UI for the JDBC connector.
Support to migrate Database to JDBC connector.
Support for encrypted/SSL and WebSocket connections in the MQTT connector.
Support for access to MQTT context properties.
Support for mapping Pub/Sub attributes to data fields in the Google Pub/Sub connector.
Timezone label is changed to Show in Timezone in the connectors.
Improved parsing in the JSON connector.
Support to prepend java:comp/env to JNDI if not available in the JDBC connector.
Documentation
Bundle of example workbooks and associated data files.
Updated version of the How to R example workbook.
Web Authoring/UX
Support for Cross Origin in the Image Box part.
Ability to assign parameter scope (Workbook or Dashboard).
Copy Image functionality in the web client.
New Editor Colors for the Dark workbook theme.
Reload data only when parameters change.
An obvious flag when the dashboard is paused.
Visualization
Support for rubber band selection in the web client.
SVG Shape visualization improvements.
Align to Time Window for time axes setting is enabled by default when creating a new visualization.
PCLI
New verb convertpermissions that takes an old Workbooks folder and scans it for GroupAccessPermissions.xml files, collects them, and outputs a single file that can then be consumed by the server.
In addition, deprecation of the following:
HTML connector in the Desktop Designer
SVG connector in the Streams Server
