Features Added in Version 2020.2.0
Web Authoring
Data table editor refactoring.
Ability to add user-defined columns (Ranking, Time Bucket, Numeric Bucket, Text Grouping).
Ability to rearrange data sources in the data table editor.
Ability to set numeric and Date/Time columns format strings in the data table editor.
Web UI for Kafka Publisher connector.
Support for localization including non-Latin alphabet languages.
Ability to modify default color palette.
Dashboard description displays in the tooltip of a Dashboard tab title.
Support to modify By Sign (Positive or Negative) colors in Workbook Theme.
Default aggregation for the Latitude and Longitude variables are now:
Mean for numeric columns
Calculation for calculated columns
External if data table contains external aggregates for the column
The empty Alpha variable has a minimum of 0 to maximum of 1 value and a step of 0.01. For non-empty Alpha variables, the minimum and maximum alpha have a step of 0.01.
Streams Server
Hierarchical storage of applications and data sources, with permissions.
New folder access restrictions to control READ, WRITE, and MODIFY level permissions to applications for arbitrary users or groups.
Migration of application and data sources to modern repository.
Support for the DESIGNER user role.
2 units draw for ADMINISTRATOR role and 21 units draw for the DESIGNER role in Altair Units licensing.
Ability to configure partitioning of topics.
Ability to set the key fields for the external input.
Manual changes in the schema of an external input operator displays the correct values.
Support for Text output to be saved in .csv format.
Correct order of columns of the .tsv output file.
Better treatment of missing Kafka.properties.
Server Improvements
Modern libraries for client-server communication (replaced Atmosphere with Stomp/SockJS).
Allow automatic log out of users based on inactivity timeout.
Ability to monitor table sizes (rows, columns, time slices) for real-time subscriptions.
Ability to delete folder name with double-byte characters.
Support for logout functionality with header authentication.
Support for Hosted Altair Units licensing.
Support for escape sequences in the Panopticon.properties file.
Update text aggregates default behavior to use all rows to determine unique values.
Subscriptions created by ad hoc services listed separately.
Setting the transportation protocol (WEBSOCKET or LONG_POLLING) for loading data from the web client is now being set in the workbook.json and admin.json files. It was previously being set in client.data.load.transport in the Panopticon.properties file.
Ability to specify the Output Files Names property for scheduler tasks.
Update Swagger-UI to v. 3.26.1
Data Connectivity
New ksqlDB static connector.
New ksqlDB streaming connector.
New Authentication DB property in the MongoDB connector to specify the database where the user is created.
Support for Load or Save Column Definitions in Text/Message Queue connectors in Web client.
Visualization
Ability to zoom into all visualizations.
Support for time series Line and Needle graphs in the Table visualization.
Ability to specify the Base value for Logarithmic scale in the Axes setting.
Support copying data from a single cell in the Table visualization.
Ability to set the Y-axis alignment settings in the Line Graph visualization when Show Last Value is enabled.
Vertical alignment of text columns in the Record Graph visualization.
Web UX
Ability to manually set Skip First n Rows value in the Text connector.
Support for the Back button respecting the workbook folder.
Support for horizontal center alignment in the Text Label control.
Internalization and localization for Asian languages.
Analytics
Ability to change the default aggregation of numeric columns in the data table.
Support for wildcard filtering (Substring or Prefix) for Free Text filter mode.
Documentation
Example workbooks overhaul.
In addition, deprecation of the following:
Breakdown Items section in the Bullet Graph visualization in Web Authoring
Visible Range options in the Circle Pack and Treemap visualizations in the Web Authoring
kdb+ Discovery and kdb+tick Discovery connectors
