Features Added in Version 2020.1.0
Web Authoring
Web UI for the Apache Cassandra connector
Web UI for the Livy Spark connector
Web UI for the Splunk connector
Web UI for JDBC Database – Streaming connector
Web UI for StreamBase 7.1 connector
Web UI for StreamBase LiveView connector
Ability to import or merge workbooks.
Ability to reorder data table parameters.
Ability to create, modify, duplicate, or remove color palettes in themes.
Ability to create or duplicate themes.
Support of filtered display of actions based on dashboard and/or data table.
New Automatic Shapes option in the Shapes variable.
Allow reordering of icon variables.
Panopticon Streams
New properties for the Kerberos integration in the Kx kdb+ connector.
Support for Python transform serialization using Apache Arrow.
Data Connectivity
Kdb+tick connector to allow full subscription syntax for service type subscriptions.
yyyy-MM-dd'T'HH:mm:ssK replaced with yyyy-MM-dd'T'HH:mm:ssX
Support for Record Path field in Message Queue Type connectors.
Kerberos integration for Kx kdb+ connectors.
Upgraded c.java to the latest version for the Kx kdb+ and Kx kdb+tick connectors.
Kx kdb+ connection pooling in connector.
Designer Improvements
Updated CefSharp version to 81.3.100.0 for iframe part and EmbedWebClient example.
Analytics
Support for month names as a new type of time bucket.
Support for sorting variables other the Size in text color variables when set to automatic mapping.
Ability to view and clear filters applied to visualizations and dashboards.
Support for specifying dashboard parameters as value sources in actions.
Update range in the Color variable when using Divide By.
Timeseries legend support to the Stack Graph visualization.
Server Improvements
New IdP signature validation properties for the SAML authentication.
UI improvements on the Workbooks tab.
New Oauth 2.0 login and logout redirect properties.
New property that takes regex used to extract the roles from the OAuth 2.0 server identity response.
Ability to view all logged in users to the server and log them out.
New special server parameters (_dashboard_name, _datatable_name, _datatable_title, _workbook_folder, _workbook_name) and renamed system parameters (_user_name, _user_id,_current_time, _last_wrorkday, _week_start, _quarter_start)
Standard content import hook and introduction of new property repository.startup.import.paths.
Faster building of dashboard parts when using the HWU licensing server.
Dynamic delivery/generation of configuration files for the different web applications which are saved in the JavaScriptConfiguration folder of Panopticon’s AppData directory.
Row stats (min/max/avg) and time slices (min/max/avg) are added into the /rest/statistic/datasource/flattened which include:
<AverageRowCount>1750</AverageRowCount>
<MinimumRowCount>1750</MinimumRowCount>
<MaximumRowCount>1750</MaximumRowCount>
<AverageTimeSlices>0</AverageTimeSlices>
<MinimumTimeSlices>0</MinimumTimeSlices>
- <MaximumTimeSlices>0</MaximumTimeSlices
Data table templates without schema are blocked from being published.
Data Framework
New Percent of Parent aggregation method.
New None aggregation method in the Pivot transform.
Support for multiple key joins.
New REGEX_EXTRACT function.
New NOW function.
Soft drill turned on for all aggregates that refer to nodes above the node like the parent or root and siblings of the node.
Visualization
Default visualization font is set to Arial 12.
Web UX
Changed client behavior to not automatically reconnect.
In addition, deprecation of the following:
Splunk connector in the Designer (Desktop)
dom4j dependency
The following properties in the Panopticon.properties file:
global.authentication.button.hidden
client.webgl.enabled
client.data.load.transport
client.pdf.multiplepages.enabled
