Features Added in Version 2020.0.0
New in Altair Panopticon 2020.0
Introduction of a new web authoring paradigm, enabling all the functionality of Panopticon Designer within the web client of the Panopticon Visualization Server:
Manage and permission workbook repositories
Create and manage analytical data pipelines (query, subscribe, transform, federate, decorate)
Create and maintain analytical dashboards for polled-, streaming real-time and time-series data.
Other server improvements include:
New user roles; Viewer, Designer, Administrator
Granular workbook permissioning
New, decentralized, workbook repository with built in support for history, synchronization and clustering
Support for deployment on Open JDK 11 and up using provided dependency pack
Python Connectivity
100-fold performance increase in Python connector and transform using Apache Arrow
Panopticon Streams
Web UI for Elasticsearch 5.x, Elasticsearch 6.x, Elasticsearch 7.x, Kx kdb+Discovery, Kx kdb+ Tick Discovery, OneTick, Python, Rserve, and SVG Input connectors
Altair licensing SDK upgraded to version 14.0.6
Parameter UI improvements
Data Connectivity
Date format yyyyMMdd added in the JSON connector
New Elasticsearch 7.x connector
Support for serialization using Apache Arrow for the Python connector
Support for the TCP scheme as the broker URL in the MQTT connector
Designer Improvements
New Pause button in the Log Window
Ability to restore color palettes in workbook theme
Support for the General Colors property in the Workbook Theme
.NET platform updated to version 4.6.1
Support for selection of general colors to use in color variables
General colors of old workbooks being integrated into their workbook theme
Analytics
Ability to set Alert active hours
Support for the Weighted Mean aggregation in the Size variable
Server Improvements
Ability to create global data extracts from Elasticsearch 5.x, Elasticsearch 6.x, Elasticsearch 7.x, kdb+ Discovery, OneTick, Python, Rserve, SVG
Support for managing workbook themes
Support for multiple default roles
Support to adapt HyperWorks Units license to new server roles
Role of the user logging on added in the Audit log
Updated default settings to improve pruning of stale subscriptions
New mechanism properties to synchronize repositories across a cluster
Authentication support when propagating content across a cluster
Support for exporting legacy files
Altair licensing SDK upgrade to version 14.0.6
New object repository of the server to facilitate object sharing and replication between multiple server nodes in a cluster
Support for Designer users to create and maintain global parameters
Better feedback when server cannot find the workbook
Higher default value for file.upload.size.max.bytes in Panopticon.properties (5300000 bytes)
Server cache moved from the data table to the data source
Separate properties for mapping headers and cookies to parameters
Support for ANONYMOUS, VIEWER, DESIGNER, and ADMINISTRATOR roles
Upgraded Jackson to version 2.10.1
Support for Open JDK 12
Data Framework
Python performance improvements using Apache Arrow
Web Client
Support for downloading legacy workbooks
Informative error message when the server license has expired
UX
Support for default filter types for Text values
Web UX
Support for dashboard tabs to be displayed in one row and the rest in a drop-down list
New Folder access restrictions to control READ, WRITE, and ADMINISTRATION level permissions for arbitrary users or groups
Ability to disable the Workbook Theme change control
Global parameters UI improvements
In addition, deprecation of the following:
Mapping of administrators through the Administrators.txt and AdministraGroups.txt files in the Visualization Server
Designer web installer (single .exe) and Java Server installer
Group services:
/workbook/group/all- GET
/workbook/group - GET
/workbook/group- POST
/workbook/group- DELETE
/workbook/group- PUT
/workbook/group/root - GET
/access/restriction/group- GET
/access/restriction/group- PUT
