Features Added in Version 17.5.0
Panopticon Streams
Web UI for Google Cloud PubSub Input connector
Support to define configuration settings in the new Kafka.properties file
Data Connectivity
Ability to define external properties to support security options in the Apache Kafka and Apache Kafka Publisher connectors
Support for Record or Time simulation in the Stream Simulator connector
Auto generation of a subscription name when left empty in the Google Cloud PubSub connector
Data source title for the OneTick Cloud connector now reflects the query table
Ability to flush out stale data and reload after reconnection in streaming connectors
Upgrade Confluent's .NET libraries for Kafka to version 1.0.1.1
Ability to define Proxy Server URI in the JSON connector
Support for connection to secondary servers in the MongoDB connector
Real-time plugins restart when losing connection with the data source
Visualization
Support for custom percentile values for Quartiles in the Box Plot
Designer
Faster field search when having 300+ columns
Analytics
New CountDistinct aggregate for the Text columns
Server Improvements
Support for deployment of Panopticon Server on Amazon Web Services, Google Cloud, and Microsoft Azure
New Designer user role
Ability to fetch the e-mail address from the properties file for Scheduled tasks
Support for sending email alerts without SMTP server authentication
Upgrade Atmosphere version to 2.5.3
Ability to create alerts on grand total
Ability to specify whether the REST login response body should contain a token info
Ability for sub-folders to inherit the GroupRestrictions properties from the Parent folder
Support to play sound for a triggered alert
Removal of stack trace in the log for AuthenticationRequiredException
Support for Header roles to populate synthetic roles
Support for Global Parameters per folder
Support for roles in OAuth 2.0 authentication
Support to reset action limit when an alert is restarted
Changed Email HTML task type name to Email Image
Upgrade of Angular, JQuery UI and JQuery versions
Upgrade Itext 4.2.0 to OpenPDF 1.3.1 and iText Asian to juniversalchardet 2.3.0
Data Framework
Support for parameterization in calculated columns
Ability to workbooks to refresh after the streaming data source stopped and restarted
New TextConcatDistinct text aggregate that supports the ability to display all existing text values in a comma-delimited list
Web Client
Filter Include and Filter Exclude options are disabled when there is no breakdown or the root is selected in visualizations
UX
Free text filters support implicit wildcard character on the input to display the list of matching values
Web UX
Support for dynamic theming of workbooks
Support to display a pop-up of the details when hovering on an active Multiple Selection Drop Down in the Filter Box and Action Drop Down
In addition, deprecation of the following:
Thomson Reuters TREP-RT connector
Using ZooKeeper to discover Kafka brokers
