Features Added in Version 17.3.0
Altair branding based on Altair Style Guidelines.
Panopticon Streams
Web UI for Solace connector
Web UI for MS Excel Input connector
Web UI for Apache Kafka Output connector
New index, sort, and invert calculation functions
New Scatter operator
New Rekey operator
New Rank operator
New Python Transform operator
New Text calculations - replaceFirst and replaceAll
Ability to export data in the Data Preview pane
Support for parameterization of the Table field in the JDBC Database and Kx kdb+ output connectors
New Save As Copy option when editing a data source
Ability to stop caching tables in the Aggregation operator
Remove topics and schemas when deleting application
Topic metrics without the JMX dependency
Date Preview pane improvements
Data Connectivity
New Panopticon Data Extract connector
New AMPS Discovery connector
New MQTT connector
Support for Time zone selection in the MongoDB connector
New Search Column option in the Apache Kafka connector
Ability to process JSON messages that are delivered as attachment in the Solace connectors
Ability for input messages to support multiple records e.g., JSON array
Visualization
Ability to display Node Labels in Stacked and standard Numeric Needle graphs
New shapes in the Scatter Plot, Table, Timeseries Combination, and Timeseries Scatter Plot visualization
Analytics
New Date/Time parts for Date, DayMonth, and MonthYear
Server Improvements
Ability to add default domain information for user authentication
Server logs when the license for the server is invalid or has expired
Ability to log Server unhandled REST exceptions
Accumulated server statistics
Data Framework
New WITHIN_PERIOD calculation
New DATEDIFF_TO_NOW and DATEDIFF_TO_TODAY time period calculations
New Ratio aggregate
Support for MONTHS and YEARS date parts in DATEDIFF and DATEDIFF2 calculations
New Text calculations - replace_First and replace_All
UX
Range Limit Error now mandatory in the Action Date Range Picker control
Server URL included in the Connecting to Server and other Authentication dialogs
Option to hide buttons in the Action Date Range Picker control
Web UX
Support for Alerts
Breakdown and pivot points updates
Support to Show Column Labels in the Table visualization
Update in the Categorical Filter in the drop-down mode (Single and Multiple) to allow clicking on the <number of selected columns> text
New Include List Selection Mode option in the Action Dropdown control
Ability to hide the parameters which are not set as Interactive in in the Input Parameters dialog
Support for double-click feature of the Breakdown column section in the Table visualization
In addition, deprecation of the following:
Alerts from Panopticon Designer (Desktop)
usecacheonfailure properties (data plugin, serialized, and service)
