Features Added in Version 17.2.0
Panopticon Streams
New Table to Stream operator
Ability to archive and republish applications
New Data Preview pane in the Application page
Ability to manually update output schema in the Join operator
Web UI for Apache Kafka Connector
Web UI for WebSocket connector
Support for the parameterization of the file path in the Text output connector
Support for parameterization for the time zone field in streams connectors
Support for conversions of timestamp to/from integer
Support to keep records in the Conflate operator
New time zone field in the InfluxDB input data source
Improved data producer key columns selection to select columns from the data source schema
Support for the creation of topics and public schema when starting an application
Ability to filter data sources
Ability to view operator settings when the application is running
Data Connectivity
New Zema (Beta) connector
Support for Spark Livy Knox
Support for key column case when generating columns in the JSON connector
Support for Time zone selection in the Python connector
Support for connection retries in the Kx kdb+ connector
Ability to update schema in the Apache Kafka connector
Viz Server
Support for Tomcat 9
Support for data source caching
Ability to create tasks to send CSV data via email
New default time format for parameterized values in the scheduler
Improved performance monitoring and diagnostics
Support to enable “http-only” and “secure” properties for the token cookie
Visualization
New Box Plot visualization
Analytics
Support for selection of specific or relative dates in the Action Date Picker and Action Date Range Picker controls
The relative time grammar supports more complex expressions and functions in the Action Date Picker and Action Date Range Picker controls
Support for parameterization in the visualization static filter
Support for Text time series as values for Actions in time series graphs
Designer
Ability to set synchronization of dashboard parts inside a panel
Ability to configure From and To labels in the Action Date Range Picker control
Ability to load and save the default parameters that were configured in the Panopticon Server
Support for non-administrator login
Data Framework
Ability to perform Max aggregation of the Date/Time fields in the Web client
New CumulativeSumByMax aggregate
Web Client
New Include/Exclude List filter mode
Web UX
Support for the Data Update Actions through the Action button to not display current values
Support for the execution of the Action rule when pressing the Enter button after entering an input value for the interactive parameter
In addition, deprecation of the following:
Support for Tomcat 8.5.x
Hierarchy Structure and Hierarchy Label options from the column configuration structure in the MongoDB connector
Hide Header Controls and Display in PDF options in the Global Filtering settings
