Features Added in Version 17.1.0
Panopticon Streams
Test Connection for Output Data Sources
New Parse operator, for parsing incoming Kafka messages
New Aggregate Methods – PREV & DELTA
Improved Layout of Directed Graph
Ability to expand the Graph or Operator Settings panel
Support to view the directed graph when running an application, including application performance statistics
Logging improvements, to always show last few 100 log entries
Web UI for XML & JSON Data Connectors
Web UI for InfluxDB Data Connector
Web UI for ActiveMQ & Rabbit MQ Data Connectors
Web UI for AMPS Data Connector
New REST output connector
Support for the From Beginning option in the External Input operator, to process historically recorded events
Support for automatic schema generation in input connectors
Support for automatic schema generation in output connectors
Enable Streams Application Monitoring via Confluent Enterprise Control Center
Data Connectivity
New Kx kdb+ Discovery connector
New Kx kdb+tick Discovery connector
Retrieval of connection details (Host, Port, Username, Password) via REST service
Support for 10 seconds timeout when retrieving schema in the Kx kdb+tick connector
Support for the latest two versions of the MongoDB server
Improved session management in the Spark Livy connector to keep sessions open in a session pool
Support for client query timeout in the Kx kdb+ connector, including when the query is queued
Support for specifying the username and password in the AMPS connector
Support retrieving Data Frames in the Spark Livy Connector
Ability for the Python connector to understand returned Pandas Data Frames, including when the data frame includes Numpy data types
Support for parsing fields of a nested hierarchy in a sub document of a JSON array in the MongoDB connector
Ability to update the schema in the Kafka, Kafka Publisher, and Panopticon Streams connectors for existing subscriptions
Option in the file connectors (JSON, Text, XML, and Stream Simulator) to not publish data files to the Panopticon Server
Ability to unpack nested numeric lists in the Kx kdb+ connector. Typically to support order book display
Support for more text data types in the Id field selection of the Kx kdb+tick connector
Viz Server
Support to generate and email HTML images of available dashboard parts under the Scheduler tab
Enhanced e-mail generation (PDF and HTML/PNG) so e-mail subjects can support special time parameters
Cache Results on Server option is now hidden forcing all results to be cached, optimizing performance
REACT Framework Web API example
SAML IDP Initiated Logout Support
Visualization
New Single Record visualization
Ability to set Needle width to the time slice. Typically used when displaying order books.
Ability to set if the last value flag will be displayed in the Line Graph and Combination Graph visualizations
Ability to set if the Set Snapshot Here option will be available in the Web Client
Ability to display the endpoints and specify the time format of the Time Axis
Ability to set whether to hide null Details pop-up values in the Web client
Support for web client Details rendering in the Pie/Donut visualization
Support for Divide By 10000 format on numeric variables, visual column settings, and numeric filters
Analytics
Support for relative dates and range ranges in the Action Date Picker and Action Date Range Picker
Hour [H]. Day [D], Business Day [B], Month [M], Year [Y]
A parameter is not selected by default in Action controls, to prevent incorrect parameters being applied
Data Framework
New POSIXMILLIS format for time parsing in Text, XML, JSON, WebSocket, and message bus connectors
(Number of milliseconds since Unix Epoch)
In addition, deprecation of the following:
Hierarchy Structure and Hierarchy Label options from the column configuration structure in the MongoDB connector
Data connectivity
Historic
MS Access
OData
Valo
Streaming
Apache QPID
Valo – Streaming
Ultra Messaging Streams
