Features Added in Version 17.0.0
New Panopticon Streams
Introduction of the new Stream Processing Engine, Panopticon Streams, which leverages the Kafka Streams platform together with the existing Panopticon Visual Analytics platform and supports:
Real Time Data Prep
Aggregation Engine
Calculation Engine
Alerting Engine
Data Connectivity
New Panopticon Streams connector
Support for 5.x and 6.x versions of the Elasticsearch connector
Support for the passing of user name and password in the Elasticsearch 5.x connector
New Schema Registry Host field in the Kafka connector
New Schema Registry Host field in the Kafka Publisher connector
Support for the STRUCT and ARRAY data types of HadoopHive in the JDBC Database connector
Increased Timeout in the Text Connector
Support for nested numeric lists in the Kx kdb+tick connector (e.g. when retrieving order book depth)
Support for users with no access to the Admin database in the MongoDB connector
Designer
Support for exporting data sources that will be used as inputs in the Panopticon Streams
Analytics
Improved synchronization of Shared and Visible variables in visualizations
Dashboard
Ability to Hide Header Controls in visualizations
Support for Enable Filtering in the Color Legend even when the Enable User Interaction property is set to false
Visualization SDK
Updated JS API to support filtering
Platform
Support to own authentication login panel
Scheduling of Data Extract Load
Scheduling of HTML email sending
Scheduling of tasks such as PDF Emailing
Ability to set what can refresh the authentication token
Web Client
Support for the synchronization of drilling in visualizations
Ability to hide header controls in visualizations
Support for the Network Graph visualization
New Pin Details pop-up
Notification message displays when a connection issue with the Panopticon Server occurs
