Features Added in Version 16.7.0
Data Connectivity
MongoDB querying and parsing numeric values improvements
Support for XML, JSON, and Text message parsing in the Solace connector
Support for Save and Load column schema in the message bus connectors
Improved Exchange and Queues configuration in the RabbitMQ connector
Title of the new data sources indicate the corresponding database table, text file, or service name
Visualization
New Order Book visualization
New Price Band visualization
Support for interpolation across NaN gaps in the Spread Graph visualization
Support for the Icons variable in the Treemap visualization
New Line Alpha property in the Line Graph and the Line Layer in the Timeseries Combination Graph
Change in the map tile provider for the Map Plot
Dashboard
Improved Time Series Legend to display Custom Single color of the visual members
Support for Default to Today as the date in Action Date Picker and Action Date Range Picker
Ability to separately enable/disable data and raw data export
Data Framework
Ability to set the range of the Date/Time stamp in the time series analysis
Support for NULL in IF calculation results
Server
Support for IdP-first authentication with SAML
Web Client
New Virtual Table mode
Support for circular parameter dependencies to be detected and error logs to be produced
Support for warnings to be logged in the browser console if duplicate parameters are detected
