Features Added in Version 16.4.0
Data Connectivity
MongoDB connector supports the current version (Community 3.4)
New Search Table option for the Join Table in the Database connector
Visualization
New Hierarchy Level aggregate
Ability to adjust the width of the Text Axis Leaf in the Table visualization
Data table loader framework for External aggregate is extended to allow aggregates to be supplied from source data
Designer
Ability to hide a dashboard part from the PDF output
Ability to set Label Position in the Action Drop Down dashboard part
Updated layout of the categorical Color variable panel
Ability to limit the date range of the Action Date Range Picker
Server
New Restful Service and batch script to clear all subscriptions
Web Client
Ability to hide dashboard tabs and toolbar icons in single dashboard workbooks
Support to zoom visualizations using mouse wheel
Support for $XAxisValueMin, $XAxisValueMax, $YAxisValueMin, $YAxisValueMax for Actions
Support for Reset Zoom when Data is Reloaded when running an Action
In addition, deprecation of the following:
Server-side rendering and Front-end Server
