Features Added in Version 16.2.0
Data Connectivity
New InfluxDB connector
New RabbitMQ connector
Support for deferred synchronous in the history query component of Kx kdb+ Tick
Visualization
New Donut Gauge Chart visualization
Ability to invert Y and Height in Numeric axes
Ability to move Dashboard parts in Designer using keyboard shortcuts
Force visuals to have a fixed filter
Additionally fix level of visible detail to 4 or 5 levels
Support to display the Grand Total or Sub Totals above the rows in the Table visualization
Transparent background for Text Labels
Needle Widths can be set to more than 10 pixels (i.e., 20, 30, 40, 50, 100) for visualizations such as Needle Graph, Stacked Needle, Grouped Needle, Numeric Needle Graph, and Numeric Stacked Needle
Request Body now enabled for both HTTP and ws:// POST requests sent to the WebSocket Server
Designer
Input validation now with tool tip popup instead of message boxes
Ability to add other visualizations inside a Panel and drag only works on the Header bar
Bitness is displayed in the About dialog
Text values in the Categorical filter list are now sorted
New Title Bar in the Filter dashboard part
New Action Date Range Picker dashboard control
Action Button supports data types including lists
Nanosecond precision support in time series and Date/Time fields
Support for Input Validation to Acton text boxes and Interactive parameters
Support Auto Divide By thousand/million/billion format on Variables
Support for Namespaces in the Kx kdb+ connector
Ability to open Designer even without access to CommonDocuments
Added new (How to Filter and NanoExecutions) and updated (VizGuide) example workbooks that ship with Designer
Support to filter on NULL values with static filter
Server
New Logs tab
Ability to upload and publish workbooks directly to the web client
Support to shut down the externally started kdb cache plugin when the Server is stopped
The cache.plugin.id default value is now removed/empty in the DatawatchBackendServer.properties file
View page source improvement in the Thin Client API examples
Support in the Back-end to force the application of userid parameter
Support in the Back-end to allow the option to periodically stop orphan data plugin subscriptions
SubscriptionThread logs errors thrown
Ability to set which SubscriptionTransport to use (Web Sockets or Long Polling) in the DatawatchFrontendServer.properties file
Ability to disable WebGL in the Server Front-end Properties file
Plugins.xml is now moved out of the pcli.jar and packaged in the Back-end Server for easier editing
Support to add failed user authentication name (userid) to the logs
New standalone JSP page for Server to validate authenticated credentials
Web Client (Client-side Rendered)
Grouped Needle Graph
Ability to drag snapshot line in the visualization
Support for Scatter Plot visualization to render Best Fit Line
Ad hoc PDF report generation
Support for Copy Raw Data
Support for Copy to Clipboard in the Copy Data export
Ability to drag snapshot line in a time series visualization
Ability to sort Table by the Text Axis column headers
Support for changing snapshot axis lines and playback in Ticks play mode through time series visualizations
The wait animation (loading spinner) is disabled whenever the playback is started through time series for non-time series visualizations
Support for multiple lines in the Action Text Area box
Support for Bookmarking
Support for iPad horizontal swipe
Support for the Shade Area Below Line in the Line Graph visualization
Rendering of Show Grid Line Through Dots in the Dot Plot visualization
Web Client (Server-side Rendered)
Ability to change breakdowns by adding, removing, or swapping columns
Visualization SDK
Support to allow change of dimensions in breakdown in the Java RDK
In addition, deprecation of the following:
DataDirect connectors such as Amazon Redshift, Cloudera Impala, IBM DB2, Greenplum, Hadoop Hive, MySQL, Oracle, PostgreSQL, Spark SQL, SQL Server, Sybase IQ, Teradata
Vertica (ODBC-based connector)
