Features Added in Version 13.8
New connectors:
ActivePivot QoD
Google Analytics
New Categorical Line Graph visualization
Ability for categorical color assignment to be done alphabetically
New aggregation methods:
CountNonZero
PercentofTotalChange
Enabled R & Python Transforms for streaming data
Panopticon Server generating HTML email with embedded dashboard images (png)
Network Graph changes:
Correct node sizing
Improved selection support and rendering
Size variable controlling the edge thickness
Ability for focusing on edges
Default Title set to display to full path
Ability to set Sequence ID for the Time Series Transform
The default Time column preview format set to short date + time
Ability to set numeric field as metric prefix in a visual Table
Ability to assign color placement for Ticker Tile (background or text)
New Select All option in ActionDropDown settings
Ability to enable Python connection on Designer start-up
Easier creation of Ticker Hit Ratio
Ability to set Reference Line variable configuration for the Scatter Plot
Double-click behavior to be applied to visualizations
