Features Added in Version 13.5
Starting 13.4.1, new command lines options were added to better support exports from the Datawatch Monarch Personal.
Refer to the list below for the new features introduced in Designer 13.5.
New connectors:
Business Objects Universe
Kafka
Improved DashboardViewModel
The first admin rights can be set for at least the current user and then the specified user
Kerberos-enabled KDB data and cache plugins
Replaced LocalDB-based data prep with in-memory engine
Control aggregation type for each component of a calculation aggregate
Improved Time format string presets in connectors
Different paths set for the corresponding separate latest/default paths for Open/Save workbook, and for browse to data file
