Features Added in Version 13.3
Support for Windows 10
Ability to embed Designer functionality
New connectors:
Teradata
WebSocket
Support for source maps when the LESS files are compiled down to CSS files during build of the Thin Client.
Ability to aggregate Text
Improvement in the Thin Client API examples
Support for the KDB+ connector to synchronous and asynchronous reads
Restructured web client modules
Improved handling of actions in Thin Client
The Add, Edit, and Delete options in the Workbook Layout are moved to the Data Table panel
Datawatch Designer 12.4 workbooks using parameterized KDB connector now forward compatible with Datawatch Designer 12.6
New Outline Only option for Scatter Plot
Free text search/completion for multiple selection filter
Support for breakdown cycling
Database connector UX improvements:
Window re-sizing
Enable On-Demand Queries check box is disabled when in Query mode with enabled aggregation
New Combinations aggregation method
Datawatch Designer migration to the Shared Licensing Assembly
Datawatch Monarch connector Open dialog extensions improvement
