Features Added in Version 13.2
Ability to launch Datawatch Designer from Datawatch Monarch
Ability to download Excel/CSV files from Datawatch Designer
For Progress DataDirect connectors, database names are populated based on the entered connection string
The New Data Connection and Cached Data list options are merged in the Connect to Data dialog
Enabled Cache option used together with Data Prep
Data Prep menu options are disabled if not possible to perform Data Prep to a column
Data Tables accessible in additional formats, where the format desired is specified as yet another URL request parameter value
Rubber band selection enabled for Touch Screen
Data Source updated in the data source control when browsing other data file
Improvement in breakdown control behavior
Long text columns are sized better
Text connectors show all TXT and CSV files in the selection list
Pie chart details pop up in IE
Support for visualization font settings
Support for labels for all nodes/segments in the Pie chart
The Published section is hidden in the Datawatch Designer Workbook summary layout when not connected to a Datawatch Server – Visualization Edition
Duplicate Data Table Name dialog is removed
Ability to expand mouse over area to include the title of the thumbnails on the Datawatch Server – Visualization Edition
Renaming of Panopticon instances
