Features Added in Version 13.1
New Progress DataDirect connectors
Amazon Redshift
Salesforce.com
IBM DB2
Informix
New Manual and Equal Density Numeric Bucketing
Improved labeling in the Calculated Column
QoD for MDX
Displaying % on the Bar and Pie Graph
Smart/Manual data binning/bucketing
Ability to switch individual Time Series graphs On/Off in the Time Series combination graph
Collapsible menu of tabs for small devices in Admin App
Rest URL Interface to Data Request Web Service
Added support for arrays and composite attributes for JMX Connector
Option to hide buttons in the ActionTextBox and ActionDatePicker
Ability to pass information about the QoD consumer to the connector
Visual Table interaction (i.e., resize columns, collapse columns or reset collapsed columns by drag-drop)
Ability to use Presentation Mode while Data Prep is in Pop Out Mode
Ability to switch On/Off individual Time Series graphs in the Time Series combination graph
Text completion for the free Text filter
Ability to change format for large numbers on Axes
Client side rendering of filters and legends
Support for touch and drag action in HTML Client on Touch devices
Ability to keep the Client session alive by configuration
Ability to show visual when the Text axis is bigger than available Screen Real Estate
Data Table Combo Box improvements
Logs for License checks
