Features Added in Version 13.0
Introduction of the Data Prep concept in Altair Panopticon Designer - Desktop Edition
New Categorical Color Legend layout
Integration enablement of the new Thin Client to web portals to enable passing of default parameters and dashboard selection
Improvement on design and layout of Iframe integration example
UX improvements in working with the data table
Visual filtering support in the Analysis Services connector
Publishing of data table templates to update referring workbooks in .NET and Java servers
Improvement on data handling in new Thin Client, both in the way data is sent from the Server and how it is handled on the Client side
Displaying of the correct error when the license file is missing or is already expired
Ability to manually change Time filter snapshot using arrow keys
Explicit sorting on Value and Title Columns in Action Drop Down
Ability to re-arrange breakdown order using Thin Client on Touch devices
Various performance improvements to the HTML5 Client
Localization support for Thin client
New dedicated Access connector
New Progress Data Direct connectors:
Oracle Database
Microsoft SQL Server
Apache Hadoop Hive
Cloudera Impala
MongoDB
MySQL
PostgreSQL
New HTML Connector
The Sybase ESP connector is now available for Java
Playback in the Time Window Filter allows movement of the snapshot either by Tick data or Calendar time
Reloading of the Thin client after acknowledging the “Resource Expired Message” warning
