Export Data Sources
You can export all the data sources of the current data table into .dsm files that will be used as inputs in the Panopticon Streams.
Exporting Data Sources
Click
beside a Data Table in the Edit Data Table view and then select Export Datasources in the context menu that displays.
Select the path where the output will be exported to in the Browse for Folder dialog.
Click OK. A notification displays.
Example 1: Only one data source is available in the exported data table
Example 2: Two data sources are available in the exported data table
Click OK. The File Explorer dialog displays with the exported .dsm file.
