Enabling Time Series Analysis
Panopticon Designer (Desktop) supports a number of data visualizations that are useful for monitoring and analyzing time series data, including the Line Graph, Needle Graph, Stack Graph, Horizon Graph, and OHLC/Candlestick visualizations.
All non-Time Series visualizations will display a selected time slice (the Snapshot) of a time series dataset, unless displaying time window calculations.
Your source data must be transformed in order to use Time Series visualization. The transform converts the dataset into a cube, where the Z axis of the cube represents time, providing a set of time slices to play through and calculate across.
When there is a time slice, but not a value determined by the selected dimensions, the value will be set to null, and in the case of a line graph, a gap in the line will be drawn.
The time slices of the output time series can be identical to the input dataset, or as typically the case with sensor data will be standardized by barring (conflating) into an appropriate granularity for display.
A source table to be used for time series must have the following properties:
A Unique key or set of keys forming a compound key for each data series. For example, you can use the Stock Symbol as the unique ID in a set of Stock Market data.
A date/time stamp of data type Date/Time.
A series of numeric or text fields providing values for each unique ID for each available Date/Time stamp.
Select the Data Table you want to use for a time series display and click Transforms in the Data Preview area:
The Datasource - Transforms dialog displays.
Check Transform to enable Time Series analysis box.
The check boxes for: one time series per data row, or close and time series with time slices that don’t align, ensure that duplicate value are highlighted, and the time cube volume is minimized.
Select the key or compound key columns from the source list of dimensions to define comparable items over time.
These define each series, and correspond to the rows of the generated time cube.
Select the column to define the time axis values (Date/Time stamp).
Set the Date/Time range of the column set in step 4 in the From and To text boxes.
This filters the time series visualization data causing less data to go over the network to the Web Client.
NOTE: The range is not calculated from the start and end values but rather from the Max (the start or the first time slice of the dataset) to Min (the end or the last time slice of the dataset) range. For example, the start and end values can be from 2000-01-01 to 2020-01-01 but the conflation still works as it takes the Date/Time range of the supplied time series.
Choose whether you want to conflate the dataset by setting the Barring period to Auto, or a defined value, between Year and Nanosecond.
Setting the barring period conflates the dataset to a defined granularity, returning a set number of data points, by default being between 50 and 1000 for Auto.
As data is potentially being aggregated across time, an Aggregate must be selected. The default conflation aggregate is Mean. Other options include: Sum, Min, Max, First, and Last.
Barring can be useful to standardize sparse time series which is especially common with sensor data, outputting values at defined time intervals, and potentially minimizing the number of rendered data points.
The available barring periods besides Auto are:
Year
Half Year
Quarter Year
Month
Day
2 Hours
Hour
Half Hour
Quarter Hour
10 Minute
5 Minute
Minute
Half Minute
Quarter minute
10 Seconds
Second
Half Second
Quarter Second
Tenth Second
Fifty Milliseconds
10 Milliseconds
5 Milliseconds
Millisecond
50 Microseconds
10 Microseconds
5 Microseconds
Microsecond
50 Nanoseconds
10 Nanoseconds
5 Nanoseconds
Nanosecond
However, when the barring period is set to None, you can enable Add Auto Identifier Column: Sequence ID.
This means that when multiple values are processed at the same time along with selected dimensions, the seqid will be added to each unique occurrence per time slice and defined dimensions, incrementing starting from 1.
Choose whether you want to interpolate for missing values.
The interpolation can replace missing numeric values with zero, the previous value, or an interpolation between known values.
Click OK.
The Date/Time field will disappear from the preview and the time series columns will be empty since they have transformed into a cube representation of the data.
Once saved, a time series data table is visually identified by the time series curve to the left of any numeric time series fields.
