Drilling into Hierarchical Displays
To drill into a hierarchical data structure, you can either:
click on the breakdown item to highlight, or
within the visualization, double-click on the item you wish to drill into.
Right-click and select the level you want to drill down into using the associated visualization.
The selected level will appear gray.
Click the gray item to return to the default view that includes all categories in the data.
