Details Double-click Options
This setting determines the action that will be performed when double-clicking on a visualization value.
Inherit
The action is inherited from the set double-click option under Workbook > Properties. The default is Drill. Other options are Filter In, Default Action, or None.
Drill
Drills into lower level details of the selected item.
Filter In
Filters in the dashboard to include selected items.
Default Action
Performs the default Action that is defined for the selected item.
None
Disables the double-click feature.
