Deleting Manual Bucket Range Limits
You can delete previously defined limits.
Display the Create Bucketing Column dialog with the manually configured buckets.
right-click on the manually configured bucket column, or
click the
of a manually configured bucket column, then select Edit in the context menu.
Hover on any of the Limits boxes, to displays its
button.
Click
of the Limit value that you want to delete.
A confirmation box is displayed.
Click OK to delete the value. The Bucket Name value is adjusted based on the available Limits.
