Delete Data Table
Deleting Data Table
You can either:
Click
beside
a Data Table in the Edit Data Table view and then select Delete in the context menu that
displays.
Select a data table in the Data Table panel in the Workbook layout and then select
from the Data Table menu
bar.
A notification is displayed showing the number of dashboard parts where the data table is used and also the number of actions where it is referenced.
Click OK to delete the data table.
