Select Default Alerter in the Alerter type drop-down list.
To modify the Alert Pop-up Caption click Settings... And add a custom caption.
Click Browse to select the sound file that will be used as an alerter. Click Play to play the sound file.
Activate or deactive Pause Realtime.
Click the OK button.
To delete Triggers or Alerts that are no longer required, click .
