Dashboard Background Color
The background color added in this section will be applied across all dashboards in a workbook.
Setting Dashboard Background Color
Select from the menu: Workbook > Themes.
The Workbook Theme dialog displays.
The background is set to White by default.
Click the Change… button beside Background. The Color dialog displays.
Select the desired background color then click OK. The selected color is displayed beside Background.
Click OK. The background color is applied in all of the dashboards of the workbook.
