Altair® Panopticon
Creating a Workbook
Creating a Workbook
  1. You can create a new workbook either by:
    • selecting New Workbook on the File menu bar, or
    • clicking the New Workbook icon on the toolbar.
    The Connect to Data dialog box is displayed.
    This allows you to create a data table from a template or by selecting a data connector.
    If you are using the Evaluation mode, the only data connectors available are the following:
      • Template: Example – StockStatic and Example – StocksTimeSeries
      • File/URL: MS Excel, SVG, Text, XML, and Altair Monarch
      • Streaming: Stream Simulator
    NOTE: Contact your sales representative to get appropriate licenses for the other data connectors.
  2. The Search box allows you to immediately find a particular connector that you want to use. Just enter the name of the connector in the Search box.
  3. Or alternatively, by opening a data source file (e.g., Excel spreadsheet) in the Panopticon Designer (Desktop), which creates a new workbook if not already open, and shortcuts the data table creation process.
  4. Select the data you want to use in the Workbook.
