Adjust Column Width in Table Visualizations
For the table visualization, the width of the columns can be automatically adjusted to fit the contents of a column or all of the columns.
Right-click on a column and then select either:
Adjust Column Width
The column width is adjusted.
Adjust All Column Widths
All of the column widths of the Table are adjusted.
Aside from selecting
either of these context menu options, you can also manually drag the Left-Right
arrow to widen or reduce the width of the columns.
Hover on a column border, the Left-Right arrow displays.
Drag the arrow to the desired width.
