Collapse multiple consecutive spaces into one space.
You can either:
right-click on a Text field
click the drop down of a Text field
then select Clean > Collapse Spaces in the context menu that displays.
All the spaces are collapsed.
Example: Description is the original column and Collapse Result shows the collapsed data.
