Align or Distribute Visualizations
Visualizations in a dashboard can be automatically aligned (by row or column) or distributed (horizontally or vertically).
Right-click on an empty space in the dashboard to bring up this context menu:
To enable these options, select two or more visualizations. Click one and then use the Ctrl key to select multiple visualizations.
Then right-click on an empty space in the dashboard.
Select any of the following options:
Align in Row
Align in Column
Distribute Horizontally
Adjusts the size of visualizations to be distributed horizontally in the dashboard. You can then opt to Align in Row or Column.
Distribute Vertically
Adjusts the size of visualizations to be distributed vertically in the dashboard. You can then opt to Align in Row or Column.
