Adding Custom Groups
New custom groups can be dynamically added to a dataset.
Select a source text column, right-click then select New Grouping Column...
The New Grouping Column dialog is displayed.
Enter the Title and then map values to the new custom group.
Values that are not mapped to a group will be assigned to the input value.
These new Custom Group columns can be used identically to a source text column, categorizing and filtering data.
