Altair® Panopticon
Aligning or Distributing Dashboard Parts
Selected dashboard parts can be automatically aligned (by row or column) or distributed (horizontally or vertically).
1.     Click a dashboard part then use then use the Ctrl key to select more. The selected dashboard parts are highlighted.
2.     Right-click on any of the selected dashboard and click any of these options:
·         Align in Row
The selected dashboard parts are aligned in a row based on the part where you clicked the Align in Row.
·         Align in Column
The selected dashboard parts are aligned in a column based on the part where you clicked the Align in Column.
·         Distribute Horizontally
Adjusts the size of dashboard parts to be distributed horizontally in the dashboard. You can then opt to align in row or column.
·         Distribute Vertically
Adjusts the size of dashboard parts to be distributed vertically in the dashboard. You can then opt to align in row or column.
