Adding Global Parameters
Follow the steps below to add global parameters with a Designer role.
1. On the Parameters tab, click the Add icon of a global folder (parent or subfolder).
A new parameter entry displays.
2. Enter a Name for the new parameter.
3. Select the Type: Text, Numeric, or Time.
4. Enter the Default Value.
NOTE |
· You can enter several default values, separated by a comma. · Single quotes on parameter value/s are removed when saving global parameters. · For the Time type, the following formats for the default value are accepted: o "yyyy-MM-dd" o "yyyy-MM-ddTHH:mm:ss" o "yyyy-MM-ddTHH:mm:ss.SSS"
5. Check the Encrypted box to encrypt the value.
NOTE |
Encryption is only supported for text parameters.
6. Click . The new parameter is added in the list.
NOTE |
Global parameters are inherited from the corresponding parent folder or subfolder.
