Drilling into Hierarchy Displays
You can drill into cross tab columns, cross tab rows, and breakdown columns.
1. Right-click on a column, select Drill and then the level you want to drill down into.
The selected level will appear gray.
2. Click the gray item to return to the default view that includes all categories in the data.
