Adding a Text Label
You can add labels or explanatory text to a dashboard using a Text Label.
1. After double-clicking or drawing a rectangle
on the dashboard canvas, click
on the Select Part pane
then click the Text Label
icon.
The Text Label pane is displayed, and the Text Label part is added on the dashboard canvas.
2. Select the Text Mode:
· Manual
Enter the text.
· Data
Select the source Data Table, Column, Aggregate, and specify the Format.
NOTE |
For text time series columns, only TextUnique and TextContactDistinct aggregates are supported.
3. Select the Vertical Align: Bottom
, Middle
, or Top
4. Select the Horizontal
Align: Left
, Center
, or Right
5. Tap the Vertical Scrollbar slider to turn it on.
6. To modify the Foreground or Background color:
¨ click the corresponding Color box to display the Color dialog to:
o select the color, or
o click
to
enter the values
for RGB
for HSL
for the Hex color code
¨ or enter the Hex color code
· set the Font type, size, style (Bold and/or Italic)
7. Set the Font type, size, style (Bold and/or Italic).
8. Click the Save
icon on the toolbar to save the
changes.
When
saved, the
notification is displayed.
