Adding an Action Text Box
The Action Text Box allows your users to submit free-text input values for a parameter associated with the action part. It can also be used for entering password parameters.
The currently applied parameter value will be displayed in the action text box.
1. After double-clicking or drawing a rectangle on the dashboard canvas, click on the Select Part pane then click the Action Text Box icon.
The Action Text Box pane is displayed, and the Action Text Box part is added on the dashboard canvas.
For this example, the following parameters are defined:
Parameter Name |
Type |
Default Value |
Ticker |
Text |
COST |
Slider Value |
Text |
0 |
These parameters are used on the Title of the Line graph (e.g., Price History for {Ticker} with Slider Value = {Slider Value:0.00%}).
2. The action text box can be configured to either be a Standalone or a Form component.
When set to Form, the action text box can be connected to any form controller on the same dashboard. The parameters that the action part can set depends on how the form is configured.
NOTE |
An action form part must be defined first to associate the action text box as a component. Refer to Adding an Action Form more information.
A line connects the component to the associated form.
If the action text box should not be connected to a form, it can be set to Standalone instead. Select the Target Parameter that will be updated by this action part.
3. Enter the Title of the text box.
If set to the Standalone type and the Title is blank, the button will be Set <Target Parameter>.
4. Select the Input Type: Text, Numeric, or Time.
If Time is selected, the Format field is enabled. Select the Date/Time format.
5. Select the Input Value Type: Single or Multiple.
If the Input Value Type selected is Multiple, you can opt to select e Delimiter character:
6. Add a custom Input Validation:
· Enter a Regular Expression to match the input data.
· The parameter will not be updated unless it passes the validation. Enter an Error Message to help in defining a better input in the Action Text Box.
7. Set the Input Sanitation:
· Enter a Replace Value which is the value to replace all matches from the regex with.
Whenever changing the text inside the action text box, this sanitation will be applied to whatever value is entered.
8. Select the Input Field Style: Text Field (One Line), Text Area (Multiple Lines), or Password.
9. Tap the Wrap Text slider (applies to Text Area).
10. Tap the Hide Button slider for the action control to update the parameter whenever the value of the text box changes.
11. Set the Button Width. The value can either be calculated dynamically (default is Dynamic) or set to a fixed value (Fixed).
12. Tap the Display in PDF slider to turn it on and include the action button in the output PDF.
13. Enter a description or useful information about the action text box into the Tooltip box.
14. To modify the style settings of the action date picker:
· click the Background box to display the Color dialog and set the background color or enter the Hex color code
· click the Foreground box to display the Color dialog and set the foreground color or enter the Hex color code
· set the Font type, size, style (Bold and/or Italic)
15. Click the Save icon on the toolbar to save the changes.
When saved, the notification is displayed.
