Altair® Panopticon
Stdev
The Standard Deviation of the selection.
The Standard Deviation is a measure of how spread out numbers are in a set. The Deviation just means how far from the normal.
Stdev is used when the group of numbers being evaluated is only a partial sampling of the whole population.
The formula:
Where  is the mean computed by getting the sum of all the items and dividing them by the number of items minus one.
Sample 1
Given a set of numbers like 12, 6, 12.
1.     Compute the mean of the sample.
Mean = (Sum of items/n), where n is the number of items
12+6+12/3=10
2.     Square the difference between each point and the mean
(12-10)^2 =4
(6-10)^2 =16
(12-10)^2 =4
3.     Calculate the average of the results in step 2 above
4+16+4/3-1=24/2
4.     Compute the square root of the result in step 4.
√12 or 3.4641
Sample 2:
Given the following sample fields:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
1
3
-1
1
1
0
$1.00
1.01
2
2
-2
2
1
$10.00
2.02
3
1
-3
3
0
$100.00
3.03
4
0
-4
4
1
$1,000.00
4.04
5
-1
-5
5
0
$10,000.00
5.05
6
-2
-6
6
1
-$1.00
6.06
7
-3
-7
7
0
-$10.00
7.07
8
0
-8
8
-$100.00
8.08
9
0
-9
9
-$1,000.00
9.09
10
0
-10
0
$0.00
0.00
Sample fields.
The Stdev for each field:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
3.0277
1.7638
3.0277
3.0277
0
.5345
$3,197.5720
3.0579
The results per field.
