Altair® Panopticon
Ratio
The comparison between the sum of a selected measure divided by the sum of the selected weight measure.
The formula:
Ratio = sum(selected measure) / sum(selected weight measure)
Sample
Given the sample data:
Region
Store
Actual
Target
North
A
$1,300
$2,000
North
B
$750
$1,000
North
C
$2,100
$3,000
South
D
$4,700
$4,000
South
E
$2,000
$2,000
Sample fields
Creating a Table visualization with Breakdowns Region and Store with subtotals and grand totals produces:
Actual
Target
North
A
$1,300
$2,000
B
$750
$1,000
C
$2,100
$3,000
North Total
$4,150
South
D
$4,700
$4,000
E
$2,000
$2,000
South Total
$6,700
$6,000
Grand Total
$10,850
$12,000
Setting the Column to Actual and the Weight Column to Target with the format set to 0.0% results to the following Ratio values:
Actual
Target
Ratio
North
A
$1,300
$2,000
65.0%
B
$750
$1,000
75.0%
C
$2,100
$3,000
70.0%
North Total
$4,150
South
D
$4,700
$4,000
117.5%
E
$2,000
$2,000
100.00%
South Total
$6,700
$6,000
111.7%
Grand Total
$10,850
$12,000
90.4%
The results per row
Computation details:
North A: $1,300 / $2,000 = 65.0%
South D: $4,700 / $4,000 = 117.5%
North B: $750 / $1,000 = 75.0%
South E: $2,000 / $2,000 = 100.00%
North C: $2,100 / $3,000 = 70.0%
South Total: $6,700 / $6,000 = 111.7%
North Total: $4,150 / $6,000 = 69.2%
Grand Total: $10,850 / $12,000 = 90.4%
Collapsing the North region results to the following Ratio values:
Actual
Target
Ratio
North Total
$4,150
$6,000
69.2%
South
D
$4,700
$4,000
117.5%
E
$2,000
$2,000
100.00%
South Total
$6,700
$6,000
111.7%
Grand Total
$10,850
$12,000
90.4%
The results per row
The rest of the computation details are the same except for the collapsed North region:
North = ($1,300 + $750 + $2,100) / ($2,000 + $1,000 + $3,000) = 69.2%
Or
North = $4,150 / $6,000 = 69.2%
Collapsing the South region results to the following Ratio values:
Actual
Target
Ratio
North
$4,150
$6,000
69.2%
South
$6,700
$6,000
117.5%
Grand Total
$10,850
$12,000
90.4%
The results per row
The computation details for the collapsed South region:
South = ($4,700 + $2,000) / ($4,000 + $2,000) = 117.5%
Or
South = $6,700 / $6,000 = 117.5%
