Altair® Panopticon
Pos
The sum of the positive values in the selection. If a value is negative or zero, the value n/a is returned.
Sample 1:
Given a list of arbitrary numbers:
Arbitrary
3
2
1
0
-1
-2
-3
0
0
0
A list of positive and negative numbers
1.     Select which values are positive.
Arbitrary
3
2
1
n/a
n/a
n/a
n/a
n/a
n/a
n/a
Negative numbers in the list
2.     Add the values 3 + 2 + 1 = 6
Sample 2
Given the following sample fields:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
1
3
-1
1
1
0
$1.00
1.01
2
2
-2
2
1
$10.00
2.02
3
1
-3
3
0
$100.00
3.03
4
0
-4
4
1
$1,000.00
4.04
5
-1
-5
5
0
$10,000.00
5.05
6
-2
-6
6
1
-$1.00
6.06
7
-3
-7
7
0
-$10.00
7.07
8
0
-8
8
-$100.00
8.08
9
0
-9
9
-$1,000.00
9.09
10
0
-10
0
$0.00
0.00
Sample fields.
The Pos value for each field in the table:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
55
6
n/a
45
1
3
$11,111.00
45.45
The results per field.
