Altair® Panopticon
Percent of Weight Total
This aggregate works like Percent of Total, with the difference that a value from one column is compared to a total data set level sum of values from another column, which is set as the “Weight column”:
[single node value from a column] / [sum of all rows from weight column in the dataset]
While Percent of Total will always summarize to 100% across the whole data set, this is not the case with Percent Of Weight Total, which can summarize to any number, depending on the differences between the Values and the Weight Values.
The aggregate value is calculated as a ratio between 0 and 1 and will be presented as a percentage value by applying a percent format string in the aggregation settings.
Sample 1
Group (Parent)
Member (Child)
Value
Weight value
Total Sum of Weight value
G1
A
10
20
125
0.08
G1
B
15
30
125
0.12
G1
C
25
50
125
0.20
G2
D
1
1.5
125
0.008
G2
E
3
1.5
125
0.024
G2
F
2
2
125
0.016
G3
G
14
7
125
0.112
G3
H
18
9
125
0.144
G3
I
8
4
125
0.064
Sample 1 Aggregated to Group Level
Group (Parent)
Member (Child)
Value
Weight value
G1
50
100
125
0.40
G2
6
5
125
0.048
G3
40
20
125
0.32
