Altair® Panopticon
Abs Sum
The absolute of the sum of the selection.
This method returns the absolute value of the sum of each item in a set of numbers.
Sample 1
Given a list of arbitrary numbers:
Arbitrary
3
2
1
0
-1
-2
-3
0
0
0
A list of positive and negative numbers
1.     Compute for the sum of the values.
Arbitrary
0
The sum of all values.
2.     Compute the absolute of zero, which equals zero.
Sample 2
Assuming that the same list of numbers has multiple groupings or breakdowns as shown below:
Grouping
Arbitrary
1
3
1
2
1
1
1
0
2
-1
2
-2
2
-3
3
0
3
0
3
0
The list of values with grouping.
1.     Compute the sum of the numbers based on the grouping.
Grouping
Arbitrary
1
6
2
-6
3
0
The sum of values per grouping.
Computation Details:
Group 1: 3 + 2 + 1 + 0 = 6
Group 2: -1 + -2 + -3 = -6
Group 3: 0 + 0 + 0 = 0
2.     Compute the absolute value of the summed up numbers above.
Grouping
Arbitrary
1
6
2
6
3
0
Final result.
Sample 3
Given the following sample fields:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
1
3
-1
1
1
0
$1.00
1.01
2
2
-2
2
1
$10.00
2.02
3
1
-3
3
0
$100.00
3.03
4
0
-4
4
1
$1,000.00
4.04
5
-1
-5
5
0
$10,000.00
5.05
6
-2
-6
6
1
-$1.00
6.06
7
-3
-7
7
0
-$10.00
7.07
8
0
-8
8
-$100.00
8.08
9
0
-9
9
-$1,000.00
9.09
10
0
-10
0
$0.00
0.00
Sample fields.
AbsSum Results:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
55
0
55
45
1
3
10,000.00
45.45
The results per field.
