Rearranging Data Table Parameters
The order of the data table parameters in the Edit Data Table layout can be rearranged.
1. Click on a parameter you want to move.
The
Hand Hover icon displays along with
the blue marker before or after a data table parameter where you can
drop the item.
2. Drag and drop the parameter to the desired position.
3. Click the Save button.
When saved, the notification displays.
