General Colors and Shared Single Configuration
For the Table, Record Graph, and Time Combination visualizations, instead of associating data table columns to the Color variable, you can modify the default General Colors and Shared Single settings.
1. Click the Color drop area.
2. Click General Colors to expand.
3. Select the General Colors such as the axis, background, border, and focus colors, that will be used in the visualization.
4. Click Shared Single to expand.
This
is the color that will be used per record that was added in the visualization,
either as a backrgound or text. By default, the color is set to .
5. To add other colors, click the Palette
drop-down list and click .
6. Click the Color box and select another color in the Colordialog or enter the Hex color code.
The new color option is added.
7. Select the General Colors such as the axis, background, border, and focus colors, that will be used in the record.
8. Click the Save icon on the toolbar.
When
saved, the notification is displayed.
