Altair® Panopticon
Sync
Synchronization determines whether the visualization should interact with other elements on the same dashboard:
Property
Row Filtering
Tap the slider to turn it on. This causes the visualization to use the categorical and numeric filters on the dashboard.
Time Filtering
Tap the slider to turn it on. This causes the visualization to use any time filters on the dashboard.
Selection
Tap the slider to turn it on. This means, the items selected in another visualization will also be selected on this visualization.
Focus
Tap the slider to turn it on. This means, when focus is set on another visualization the system will also set focus on this visualization.
You can also enable the Synchronized Variables  of the visualization’s variables.
