Altair® Panopticon
Parameterization in Calculated Columns
Given Table 1:
Group
Name
Value
X
A
2.00
X
B
3.00
Y
C
4.00
Creating a new numeric parameter X with a value of 7:
Then adding calculated columns AddOne = [Value] + 1 and AddX = [Value] + {X} will result to:
Group
Name
Value
AddOne
AddX
X
A
2.00
3.00
9.00
X
B
3.00
4.00
10.00
Y
C
4.00
5.00
11.00
Sample 1
Below is the defined breakdown in a Table visualization:
This Table visualization is showing the grouping of the columns based on the breakdown hierarchy with AddOneSum, AddXSum, AddOneCalc, AddXCalc as Visual Members with the corresponding aggregates and the X value is set to 7:
Column
Aggregate
Value
Sum
AddOneSum
Sum
AddXSum
Sum
AddOneCalc
Calculation
AddXCalc
Calculation
Adding an Action Dropdown in the dashboard with a Set Parameter mode:
And given Table 2:
Value
0
1
7
12
Will result to these Table values:
