Altair® Panopticon
Time Window Calculations
Time Window calculations allow new columns to be created that are based on a defined time window.
As a consequence, there are several additional functions:
Function
COUNT_TIMEWIN
Like SUM_TIMEWIN, but simply returns the number of time slices between the defined time window, that have non-null values.
CUMSUM_TIMEWIN
The cumulative sum of Time Series value between start and end times.
Alias for SUM_TIMEWIN(“Measure”,TimeWindowStart,Now).
LOOKUP
The value of a Time Series measure at a specific time.
MAX_TIMEWIN
The maximum value between the start and end times.
MEAN_TIMEWIN
The mean value of the Time Series between the start and end times.
MIN_TIMEWIN
The minimum value between the start and end times.
NOW
Returns the system Date/Time in default or provided format.
Example: NOW() or NOW("yyyy MMM dd HH:mm:ss").
PRODUCT_TIMEWIN
The product of the Time Series values between the start and end times.
STDEV_TIMEWIN
The standard deviation of the time series between the start and end times.
STDEVP_TIMEWIN
The population standard deviation of the time series between the start and end times.
SUM_TIMEWIN
The sum of Time Series values between start and end times.
And three additional measures:
Function
SnapshotTime
The time slice at the Snapshot Time
TimeWindowEnd
The Time slice at the end of a time window
TimeWindowStart
The Time slice at the start of a time window
   NOTE
When using Time Windows calculations, fields referenced by the calculation should be enclosed in double quotes and NOT square brackets.
For example, using the Time Series column PRICE, the following calculations can be created:
Function
Difference Between Start and End of Time Window
LOOKUP(“PRICE”,TimeWindowStart)-LOOKUP(“PRICE”,TimeWindowEnd)
Time Window Maximum value across
MAX_TIMEWIN( “PRICE”, TimeWindowStart, TimeWindowEnd )
Time Window Standard Deviation
STDEV_TIMEWIN( “PRICE”, TimeWindowStart, TimeWindowEnd )
Variance since Time Window Start
( [PRICE] - LOOKUP(“PRICE”,TimeWindowStart) ) / LOOKUP(“PRICE”,TimeWindowStart)
