Altair® Panopticon
Text Calculations
Text calculations allow new text columns to be created based on input string manipulation.
They typically use one or more of the following operators:
Function
CONCAT
Concatenates two strings together.
DEC2HEX
Converts a decimal number to hexadecimal.
Example: DEC2HEX(255, 2) = "FF"
FIND
Returns the starting position of a text string within another text string.
IFTEXT
Returns a string based on the expression being evaluated to true or false.
LEFT
Returns the left most characters from a string producing a new string.
LEN
Returns the number of characters in a string.
LOWER
Returns the input string in lower case.
MID
Returns the characters from the middle of a text string, given a starting position and length.
PROPER
Converts a text string to proper case; the first letter in each word in uppercase, and all other letters in lower case.
REPLACE_ALL
Replaces all of the instances of the pattern_to_replace with the replacement_text.
For example:
replace_All(input_text, pattern_to_replace, replacement_text)
replace_All("ABA", "A", "X") = "XBX"
NOTE: Only input_text may be null.
Special cases:
·         If input_text is null, the result is null.
If pattern_to_replace is empty, it's considered to occur at every position in the input_text (including before the first and after the last character).
REPLACE_FIRST
Replaces the first instance of the pattern_to_replace with the replacement_text.
For example:
Replace_First(input_text, pattern_to_replace, replacement_text)
Replace_First("ABA", "A", "X") = "XBA"
Note: Only input_text may be null.
Special cases:
RIGHT
Returns the right most characters from a string producing a new string.
TRIM
Returns the input string stripped of leading or following spaces.
UPPER
Returns the input string in upper case.
In addition, the IF calculation can be used on text inputs to define the condition, to produce numeric output.
Example: IF([SIDE]=”BUY”,[SIZE],-[SIZE])
Calculation Data Type
The data type of a calculation will default to text if a text column is used in the calculation.  This type can be set manually by checking the “Set type manually” checkbox.
And then picking the appropriate output data type.
