Altair® Panopticon
Numeric Calculations
Numeric calculations allow new numeric columns to be created.
They typically use one or more of the following operators:
Operator
Name
Logical NOT
Logical NOT.
Integer Division
Integer Division
Logical AND
Logical AND.
Multiply
Multiplies two numbers.
Add
Adds two numbers.
Subtract
Subtracts two numbers.
Divide
Divides two numbers.
Less than or equals
Less than or equals to.
Not Equals
Not Equals.
Equals
Equals.
Greater than or equals
Greater than or equals to.
Raises to the power
Raises number to the power of number2, number1 ^ number2.
Logical OR
Logical OR
And one or more of the following functions:
Function
ABS
Absolute value, which can be used as ABS(X).
ATAN
ArcTangent function which can be used as ATAN(X).
CEIL
Ceiling function.
Examples: CEIL(-3.2) = -3, CEIL(3.2) = 4.
COS
Cosine function which can be used as COS(X), where X is a real-type expression. COS returns the cosine of the angle X in radians.
COSH
Cosine Hyperbolic function which can be used as COSH(X).
COTAN
Cotangent function which can be used as COTAN(X).
EXP
Exponential function which can be used as EXP(X).
FLOOR
Floor function.
Examples: FLOOR(-3.2) = -4, FLOOR(3.2) = 3.
HEX2DEC
Converts a hexadecimal number to decimal.
Example: HEX2DEC("FF") = 255
IF
Conditional Statement
The IF(b, case1, case2) function provides branching capability.
·         If b is True, then it returns case 1.
·         If b is False, then it returns case 2.
·         If b is a numeric value 1, it is equal to True.
·         If b is a numeric value 0, it is equal to False.
NOTE: By default, the function returns a value of data type Text. To force the data type to numeric, you can either use “Set type manually” or do a calculation with a numeric value, such as multiply by 1.
Examples:
IF([Actual] >= [Budget], “Good job”, “Not done”)
IF([Some_Number] = 0, 0, 1/[Some_Number])*1
INTPOW
Raises Base to an integral power.
Example: INTPOW(2, 3) = 8. Note that the result of INTPOW(2,3.4) = 8 as well.
ISNULL
If the measure Is Null or NaN, then 1 is returned, else 0 is returned.
LN
Natural Log which can be used as LN(X).
LOG
10 Based Log which can be used as LOG(X).
LOGN
The LogN function returns the log base N of X.
Example: LOGN(10, 100) = 2
MAX
Maximum of two input values.
Example: MAX(2, 3) = 3
MIN
Minimum of two input values.
Example: MIN(2, 3) = 2
MOD
Remainder of division.
Example: MOD(7, 3) = 1
POW
Raises Base to any power. For fractional exponents or exponents greater than MaxInt, Base must be greater than 0.
RANDOM
RND(X) generates a random INTEGER number such that 0 <= Result < int(X). If X is negative, then result is int(X) < Result <= 0. RANDOM(X) generates a random floating point number such that 0 <= Result < X. If X is negative, then result is X < Result <= 0.
REGEX_EXTRACT
Returns matching data from the value based on regex. Expression is REGEX_EXTRACT("value", "regex")
SIGN
SIGN(X) returns -1 if X<0; +1 if X>0, 0 if X=0; it can be used as SQR(X).
SIN
Sinus function which can be used as SIN(X), X is real-type expression. SIN returns the sine of the angle X in radians.
SINH
Sine Hyperbolic function which can be used as SINH(X).
SQR
Square function which can be used as SQR(X).
SQRT
Square Root function which can be used as SQRT(X).
TAN
Tangent function which can be used as TAN(X).
TRUNC
Discards the fractional part of a number.
Examples: TRUNC(-3.2) = -3 and TRUNC(3.2) = 3
